CA Traveler wrote:
CT_WANDERER wrote:
I have not finished reading this post. But I see you are saying you have not 12 volt reading from your batteries. You must have 12 to get your reffer working and many other things in the RV. You say they work on shore power. Is your converter working? When on generator? Just a quick thought and I will read more.
He posted 6.5V on the 6V batteries. The refer appears to be a second problem.
AUX batteries (4-six volt) do not register anything on the cabinet readout. I cleaned all the terminals on the 6volts, still nothing on cabinet meter. If I touch volt meter to + and - of each battery I get about 6.5 VDC.
MAIN batteries register normal range on meter in cabinet.
I understood it as he was not showing any 12 volt on his panel on the aux battery, but he was showing 12 volts on the other main battery.
