SacsTC wrote:
Branman1971 wrote:
I checked the transfer switch and I have 220 coming in, and 220 on the load side going out, but gotta get some fuel so i can start the generator. Update on Generator side in a little while. I am sure you are all on the edge of your seats. lol
No, if plugged in to an RV 50 amp, you have 2 lines at 120. You should have 120V measuring between Line 1 and neutral and 120V measured between Line 2 and neutral
Yes, but across the hot legs, it's 240vac. These feeds are of opposite potential and the coach breaker box is of the same configuration as any stick house.
