dougrainer
Apr 22, 2021Nomad
You need to explain in more detail
1. What year RV?
2. Did the slide work previously correctly?
3. Did the slide malfunction and you started the override or went to the web for the LCI/Powergear link you posted?
4. Have you replaced a motor or the controller OR the wall touchpad?
5. The reason you may have the fault in normal operation is the fact the system sees one motor retracting and the other extending.
6. There is an easy way to determine and possibly fix. Just reverse the heavy duty pos and neg wires at one motor. That will cause that motor to then operate in synch with the other motor.
7. Last, go the the LCI/Powergear tech site and you will find the Digisync wall switch programming instructions. Your link does not have the programming instructions. Doug
1. What year RV?
