DAWg134
Aug 31, 2013Explorer
Yes, if you happen to have one laying around, then using a variable resistor as a voltage dropping resistor to establish a +1.5 Vdc clock voltage will work quite well.
Just a word of caution, though. Be absolutely certain that you have the variable resistance set towards the top of the range before you connect it. If the resistor is near-zero resistance when you hook it up, you will surely fry the clock innards because you will be applying the full 12 volts to the circuit.
Furthermore, unless you have an ongoing need for that variable resistor elsewhere, you could actually leave it in place after you have set the voltage.
Dale
Dale
38,771 PostsLatest Activity: Apr 15, 2026
