Executive45
Sep 21, 2013Explorer III
Bumpyroad wrote:vic46 wrote:
Just curious. What is a "temporary" deposit?
refundable?
bumpy
He wrote a bad check....:B:B:B...Dennis
If the seller has all the records, go over them carefully. Ensure everything was done in a timely manner. IE oil changes regularly, filter changes regularly etc. If he's meticulous with his coach enough to keep records, he should be changing the oil and filters at least once a year. If his records check out, then I wouldn't hesitate to buy the coach. My Dynasty had every record since it was born. At 109,000 miles I only had a couple issues with it and it still ran strong when I traded up to the Exec....Tires will save you about $4k but still check the date codes.....good luck....Dennis
38,767 PostsLatest Activity: Jan 13, 2022
