BTPO1 wrote:
You could use colored tape on the garage floor and follow the tape with the rear wheels as you back into the garage. Using the drivers side mirror that should be no problem. JMO
This is what I was going to suggest. We recently moved from the San Diego area to Lake Havasu into a brand new home. This home came equipped with a 15.5 wide x 53' long RV garaged attached to the two car garage. Prior to move in, while the house was still un-occupied, I authorized the commercial epoxy coating of all the garage floors.
And, I too need that coach to be almost dead center, EACH TIME I BACK IT IN, so that I can open the compartment doors and do work, retrieve things etc. So, while that coating was being applied to the floor, I had submitted to them in a drawing, two bright, 2" yellow lines, equal distance from each side wall.
Those lines are the lines that I use to back the rear tires right alongside. It works flawlessly. I can put that 36' rig, in the EXACT same spot, each and every time, in a matter of about 30 seconds. It sure saves from filling up that garage with diesel smoke from jockeying around trying to get it centered. Those lines, are epoxy paint, and, they are under the final two, epoxy clear coats. So, they will NEVER wear off. Hope this helps some. Good luck.
Scott
P.S. The mess you see in the back of the new RV garage is now gone, all that's there is a nice work area.
