dougrainer
Sep 30, 2016Nomad
BigMac wrote:
Doug - Thanks for your detailed recommendations. One added question. I am curious about the segment of MH water line that ends at the shutoff valve for the refrigerator water line. When I use the normal water antifreeze to winterize the remaining plumbing in the MH, does that segment become filled with antifreeze (I assume it does), and when I de-winterize next spring, should I be concerned about that antifreeze being introduced to the fridge? Or do I attached tubing to allow that antifreeze to purge overboard until the water runs clear, and then hook the lines back up for the fridge? Thanks.
This is not a problem if you blow out with air. If you do NOT want antifreeze in the refer icemaker system, but need to get the FEED line to the refer with antifreeze, take the feed line loose at the Refer water line connection point and let the antifreeze flow out. Then in the spring, run fresh water thru that line until the Pink is gone then reconnect the line. Doug
