klutchdust
Sep 04, 2022Explorer II
Pre cool everything before it goes in the fridge. Cardboard holds heat so keep those beverages loose and not in packaging. Like was said use fan inside fridge. i have ordered a fridge fan that will be wired into the door light wiring. Also replacing the thermistor with one that you can set the temperature on vs sliding the plastic up and down the fins.
When the outside temp goes above 90 the fridge will start to struggle. Also, these fridges work better on propane thanelectric. Propane heats the chemicals better that are in the system.
