- wcjeepExplorerOnly use what is recommended for your specific engine. Do not mix. Do not use universal. Do not rely on color. Its more expensive, but, I prefer pre mix. Never have to worry about minerals or mixture ratio. The engine costs too much to mess around.
- Sully2Explorer
moisheh wrote:
Peak Final Charge is the way to go. The only drawback is if you have a hose that blows and you are not in a major area that coolant may not be available. Truck stops and SOME NAPA's do carry Final Charge. I keep 2 gallons of the concentrate in our unit as well as some distilled water.
Moisheh
Buy the Cummins/Fleetwood product. A LOT of places have it or can get it quickly - moishehExplorerPeak Final Charge is the way to go. The only drawback is if you have a hose that blows and you are not in a major area that coolant may not be available. Truck stops and SOME NAPA's do carry Final Charge. I keep 2 gallons of the concentrate in our unit as well as some distilled water.
Moisheh - wolfe10Explorer
Weldon wrote:
I have a 7.3 ford diesel and am looking at the "Extended Life Coolants". I am looking for one that would enable me to NOT use the additive that prevents cavitation.
Maybe Peak final charge.
Check out the newer generation OAT-based diesel coolants. - WeldonExplorerI have a 7.3 ford diesel and am looking at the "Extended Life Coolants". I am looking for one that would enable me to NOT use the additive that prevents cavitation.
Maybe Peak final charge. - wolfe10ExplorerLooks like they have several offerings styled: "Extended Life Coolants".
Here is another extended life coolant that would not be suitable for diesel engines: http://www.prestone.com/enmx/products/antifreeze_coolant/product_list - Looks good on their website.
Prestone - mci7ExplorerI just had my radiator replaced due to the external fins falling off from salt I guess, the inside looked like new, no sediment, not clogging of the tubes, just parfect looking all due to using the ELC, the coach is a 2001 model with 114 K miles.
New radiator went back on with 50/50 ELC & Distilled water.
Cheers
Dave M - wolfe10ExplorerA quick look at the specs saw no mention of "for diesel engines". For the best answer, look up the Mil Specs for the coolant in your Cummins owners manual and compare to the Mil Specs on the Prestone produce.
There are basically two types of coolants for diesel engines, particularly critical for linered engines like you ISC:
1. Low silicate for diesels with added SCA
2. New generation OAT-based coolant for diesel
Use even an excellent coolant meant for gasoline or non-linered diesels and you will have cylinder wall erosion. - Sully2ExplorerIf you have a Cummins engine....just use their Antifreeze. Youll always have someone to call if you develop any sort of problem(s)
38,782 PostsLatest Activity: Sep 19, 2026
