dons2346
May 23, 2016Explorer
You should have a shut off valve so you can shut off fuel to the filters. Turn it off and remove the filters one at a time and replace. Turn on the fuel valve and use the ignition to prime the filters. Do this 6-10 times, do not engage the starter. If it doesn't start, then repeat the 6-10 times prime.
Works for me with a ISC
38,767 PostsLatest Activity: Jun 10, 2019
