SpurHntr
May 25, 2016Explorer
dons2346 wrote:
You should have a shut off valve so you can shut off fuel to the filters. Turn it off and remove the filters one at a time and replace. Turn on the fuel valve and use the ignition to prime the filters. Do this 6-10 times, do not engage the starter. If it doesn't start, then repeat the 6-10 times prime.
Works for me with a ISC
No shut off valve to be found.
