golfman_1ExplorerJun 17, 2016problem roof airDometic 13550 roof air. When it is 92 outside the compressor runs a little and cuts off never getting to set temp 0f 74. Whens its 82 it works fine and keeps it cool. Help
the_bear_IIExplorerJun 17, 2016X-2 Freezing...check the sensor ours fell off once and I put it back in place. No problem since.I did find that if I set the thermostat a little bit warmer than the coldest setting it would prevent the icing problem.
Related ContentRoof problem?roof airAir Conditioner vibrationRoof problemsAtwood water heater problem
