Tripalot
May 30, 2014Explorer
OldRadios wrote:
Get a weight on all four sets of wheels. See what the difference is between drivers and passengers side. Sounds like the max weight might be over the limit on one side. Tough to do on a E450 chassis with a short box though. Make sure you check it with the Toad attached.
While at the FMCA Rally in Perry, Ga. last March we had the M.H. weighed with toad attached, full fuel, full water tank, empty grey & black and loaded with the usual stuff as we were traveling home after being in Florida for the winter. All weights were within specs and this information was provided to Ford. Although within specs. the rear passenger side was a little heavier than the driver's side. Not much can be done to change that as the main storage compartments are in that rear corner - also fridge is on that side but more in the middle.
We did shift the wine and beer supply to a different location though!
