allbrandauto
Jun 24, 2014Explorer
if not the bulb you have a ground problem to check it use a 12 volt test light ground one end of it use the probe on brass part of bulb turn on parking lights if test light lights up you have a ground problem check ground wire the same way if it doesn't light up you have a bad socket
