donk0501's avatar
donk0501
Turn signal problem
2003 Gulfstream Class A (freightliner chassis). This morning when I checked my turn signals prior to hitting the road I encountered this problem: regardless of whether signaling a left or right turn, both sides of my lights flashed. I double checked to assure the hazard lights switch was in the off position, changed both relays for the hazard lights, replaced the turn signal fuse, all of which failed to solve the problem. Any ideas what to check next other than a possible short in the wiring harness?
