TIMETOTRAVELExplorerJun 24, 2014problem with right front turn signalI have a 2003 Tiffin Allegro Bus, when you turn on the head lights the right signal light... lights up on the dash , even without pulling up the blinker arm, but not on the outside. If you do pull up...Show More
enblethenNomadJun 24, 2014Lamp outage indicator. Some where on that side is a lamp out. Could be side marker, turn signal or taillight.
Related ContentAtwood water heater problemTurn signal problem...Troubleshoot fridge problem...Turn signal problemTV antenna signal problem
