tork'd wrote:
after a very pleasant 10 days in New Orleans, we had a major problem with one of our slideouts.
drove thru a hard rain then stopped from fuel. when I turned the ignition off and the lounge slide moved out as far as it could. only stopping when it could not go any further due to the slide lock on the forward upper area of slide.
after several attempts to retract slide, and making no headway we decided to call it a night. after @ two hours I tried the slide switch it did work. decided that I would resume the trip home and after arriving home the same thing happened when ignition turned off.
has any one had this happen?
if so, what did you find as the source?
thanx for any help.
Don and Kelly
Don in my coach it is recommended that you start your engine when retracting or extending the slide. It has to do with running a solenoid!
