booster
Aug 16, 2015Explorer
Being grandfathered usually will also be the term used to allow things to continue if they have been done as an exception. The best example would be a variance in construction. If you get a variance allowing you to be closer to a lot line than code and then the add a rule to the code that says no more variances for that close, you would be grandfathered in. The same thin should apply if you get an approval to park a B in the driveway, which was Rodger's example, from the HOA, as an exception, they shouldn't be able to recind that later. Of course a lot of HOA's are run by wannabe bosses and kings, so it can get a little out of hand.
