SpurHntr
May 20, 2018Explorer
dougrainer wrote:
Should be mounted in the front outside drivers side Storage in front of the LF tire on the Ceiling of the storage compartment. Hopefully you do not need a new controller as LCI/Atwood no longer have them. Doug
looked in that bay twice....never thought to look UP!!!!
Will check
Yeah, was told the controller is bad by my local dealer. The retrofit kit from Atwood they say would be like $4500 installed, apparently comes with new jacks.
I paid $1600 for a new rear jack WHICH WAS SUPPOSED TO FIX THE PROBLEM per dealer but didn't...far as that jack goes I knew it was bad,,,on an ALL RETRACT move last year that jack stayed extended then it collapsed suddenly before i could get the pad to extend the other jacks....so, I needed rebuilt or replace (i just went with new, was $1100 to do myself and i like doing a lot myself but felt that was $500 well spent considering the tenuous airbag situation with faulty levelers being tied together not to mention my lack of a pit to work in)
Want to swap out a manual 4 way switch by GAMA and install a temporary switch to dump air too while at it. Good buddy of mine is an electrician who is going to help me out.
