wa8yxm
Jun 09, 2018Explorer III
I see this question often. That keypad on yoru dash.. That's the controller
Now there is a sensor box it is most likely in your basement but may be under the RV. Take a ball of twine tie it to the right front jack and then run it around the left rear, across to the right rear than to the left front (NOTE you can start at any corner)
Where the strings cross.. X marks the most likely spot.
38,782 PostsLatest Activity: Sep 10, 2026
