trutone wrote:
The bleeder valve has a tube connected to it. The tube is set at the 80% level in the tank. When filling, the liquid reaches the tube and the liquid comes out the valve. I don't think it's a good idea to fill using the OBD valve. That's only to prevent the tank from rupturing from too much pressure. Get the tank checked!
The O
PD is not a pressure relief device, it is an "
Overfill
Prevention
Device". The "bleeder valve" is the primary full level indicator, while the OPD serves as a backup if the attendant is not paying attention or attempts to overfill the tank or cylinder. Both ASME tanks and DOT cylinders have OPD's, although the implementations are slightly different.
