CA_Traveler
Jun 07, 2019Explorer III
RVs have two stage regularos. Connecting to the low pressure RV hose with a typical BBQ single stage regulator may have problems regulating or freezing. But it might work for you.
On my rig I could disconnect the high pressure side of the regulator and the fitting is the same as a BBQ tank. See the picture.
I installed this connector (basically a extend a stay) for the high pressure connection (the one with the red shut off valve) which allows me to connect to any BBQ.
Of interest to the OP is the top vertical port which is the standard high pressure port to connect to a portable tank.
Click For Full-Size Image.
38,756 PostsLatest Activity: Dec 17, 2017
