Having a problem with the propane side of the fridge not working..read where if you are above 5000 feet elevation, the propane side would probably not work and recommend using electric..if you don't h...
Urban myth! When we got our first fiver our home was at 8512' (Summit County CO) and all our camping was above that! We found, even in our stick home that because of the elevation cooking things like potatos took more time! When in the trailer, using propane, cooking took about the same time! Higher elevation- less oxygen- less efficiency of heat source. But propane always worked fine, just a bit slower.
