Old-Biscuit
Dec 30, 2013Explorer III
Typically this is a problem with truck campers due to the strange aerodynamics/shape of campers.
Usually NOT a problem with MHs.....smooth sides etc.
The furnace runs good when parked?? No problems lighting off/staying lite/blowing hot air??
Where on MH is furnace located outside?
One thing to check is that furnace is getting the right amount of propane.
Check that propane pressure at furnace is 11" WC with at least 50% of propane devices in service.
Other devices may work with lower propane pressure but the furnace is a hog and needs good/high pressure to sustain flame especially if air flow is disrupted.
Until you know that furnace propane pressure is correct......any other 'fixes' would be just chasing your own tail
