dougrainer
Apr 14, 2014Nomad
Dometic or Norcold refer or aftermarket? Dometic, you MUST transfer the burner flue baffle or the refer will not cool on LP. Norcold cooling units(OEM, not aftermarket) come with the baffle already installed. Regardless, if it does NOT cool on LP and the LP pressure is at least 11.5 inches, then the odds are the baffle is NOT installed. The baffle is only for LP operation. It is a swirl shape and distributes the LP flame in a circle to evenly heat the boilet flue. Doug
38,782 PostsLatest Activity: Sep 10, 2026
