dougrainer
Apr 14, 2014Nomad
bigred1cav wrote:
Dometic, double side by side doors, ice maker. Haven't tried electric yet. Have no idea how to check if gas is lit.
Thanks, TerryOld-Biscuit wrote:
How long has it been running?
Does the gas flame come on?
Does it cool on electric?
IF cools on electric OK......
Then need to check that flue baffle is correctly positioned...too high/low results in improper heat transfer
Flue tube.......carbon build up will reduce heat transfer
Dirty burner/orifice...improper flame
What fridge do you have?
It lights automatically. Did you do the Cooling unit or did someone else? You need to run it on 120 volts for 24 hours and see if it works. IF it does NOT light, the "Check" light should be ON on the inside eyebrow panel. There will be no indication if it fails to work on 120 volts other than no cooling.
38,782 PostsLatest Activity: Sep 10, 2026
