Licreek's avatar
Licreek
Propane into my rig
Hello all. I just got my rig set up in an rv park for the winter in Texas. It was a very difficult park and lots of leveling. Not a fun set up. Now iv discovered there is NO propane service to the park. ****! What can I do? Is there a way to hook up a portable bottle to the fill valve on my rig to supply propane. Any help?? I can move my rig every time I need propane?? Thank you, Lee
  • Search for propane suppliers in your area.
    NOT campgrounds but "real" propane dealers.
    They can sent out a truck to fill your built-in tank.......but ask the cost first.
    That will be an easier option but not as versatile and maybe a tad more expensive. But maybe not; don't know until you ask.
  • Install a propane 'TEE' between your propane tank Service/Vapor Valve and the LP Regulator.
    Then you can attach a 20#, 30#, 100# propane cylinder to the hose/Tee.
    Close MH Service/Vapor Valve...open propane cylinder valve and feed your MH Propane System via the portable propane cylinder
    Which can then be taken and refilled as needed
    Camco Propane TEE and Hoses
  • https://www.amazon.com/gp/product/B0014JG7RQ/ref=ox_sc_sfl_title_19?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
    Camco Tee, Goes between tank and supply line so you can hook up a portable tank to run propane appliances in your rig. You can also hook up outside stoves and lanterns etc. Easy install but you need to make sure there are no leaks which is easy to check with some soapy water.
