dougrainer
Oct 14, 2015Nomad
1. You DO NOT have a 100 gallon LP tank. NO Motorhome has a 100 gallon LP tank. You probably have a 100 POUND rated LP tank which has about 24 to 28 gallons of Liquid LP.
2. You could run 6 months on LP if just using the refer
3. The refer will NOT run continuously on LP. It will run ONLY when the tstat calls for cooling.
4. The RV's (refer) is designed to run on LP in transit. IF you run the Genset to run the refer, That will cost you from $2 to $4 per hour(fuel cost) to run the Genset and also make you have top do oil changes quicker because you will be needlessly running the Genset. Doug
38,766 PostsLatest Activity: Jan 10, 2026
