dougrainer
Oct 15, 2015Nomad
NoVa RT wrote:
I run the fridge off the battery when traveling, after cooling it down while plugged in at home before leaving. I don't get the preference for propane. Sure, you don't use that much, but you don't use any off the 12V. I figure I'll just use the propane when I run the furnace (mostly cook on an outside grill) and it'll last a very long time.
Because you have tunnel vision. Your Particular Motorhome, has the optional 3 way refer. Usually, only your type motorhomes have a REAL 3 way refer that has a 12 volt heating element(3rd way). BUT, that 12 volt element does NOT cool the refer. It only maintains the existing temp while it is on 12 volt. The OP has the more standard 2 way (LP and 120 only). Doug
38,766 PostsLatest Activity: Jan 10, 2026
