DrewE
Oct 15, 2015Explorer III
NoVa RT wrote:
I run the fridge off the battery when traveling, after cooling it down while plugged in at home before leaving. I don't get the preference for propane. Sure, you don't use that much, but you don't use any off the 12V. I figure I'll just use the propane when I run the furnace (mostly cook on an outside grill) and it'll last a very long time.
A large part of the preference comes from the many two-way fridges that don't have a 12V element. The choices are propane or 120VAC power--and if you aren't running the generator while traveling for other reasons such as running an air conditioner, and don't care to buy and install an inverter for fridge use.
In many cases where there is three way power, the 12V element is also significantly less powerful than the burner or the 120V element, so there is less cooling available when running on 12V power. On hot days, that can be an important consideration--you might not be able to maintain sufficiently cool temperatures.
38,766 PostsLatest Activity: Jan 10, 2026
