msmith1199
Oct 15, 2015Explorer II
dougrainer wrote:msmith1199 wrote:DrewE wrote:NoVa RT wrote:
I run the fridge off the battery when traveling, after cooling it down while plugged in at home before leaving. I don't get the preference for propane. Sure, you don't use that much, but you don't use any off the 12V. I figure I'll just use the propane when I run the furnace (mostly cook on an outside grill) and it'll last a very long time.
A large part of the preference comes from the many two-way fridges that don't have a 12V element. The choices are propane or 120VAC power--and if you aren't running the generator while traveling for other reasons such as running an air conditioner, and don't care to buy and install an inverter for fridge use.
In many cases where there is three way power, the 12V element is also significantly less powerful than the burner or the 120V element, so there is less cooling available when running on 12V power. On hot days, that can be an important consideration--you might not be able to maintain sufficiently cool temperatures.
I didn't even know they put three-way refrigerators in motorhomes. I never saw one in the MH's I looked at. Mine is two-way. I have a onboard 2000 watt inverter in my motorhome and the only things not even plugged into that inverter are the A/C's and the Frig. I'm assuming that the reason for this is that National RV decided that the frig was a lot more efficient (?) using propane when 120 volt a/c wasn't available.
No, 3 way refers in the 6 and 8 cubic foot size are not that efficient on 12volt Heat Element to maintain the temp. OEM's including National NEVER, thought about the refer source of power. Some just include the refer 120 plug on the Inverter because they do not want to run extra 120 wiring. Others Free up the refer as they realize there is no reason to run the refer on 120 when you can run on LP. LP or 120 are the same basic BTU's of heat. One is not better than another UNLESS, your 120 line voltage is below 110 or your LP pressure is low. Doug
You start by telling me "No" I assume which was meant to tell me I was wrong. Then you point out in caps that National NEVER thought about the refer source of power. How do you know that a giant motorhome builder NEVER thought about power to the refer? I don't even understand that statement at all. You then go on to state why they power them the way they do including "Others free up the refer as the realize there is no reason to run the refer on 120 when you can run on LP" which is what I said that you implied I was wrong about??? So how did they "realize" this if they never even thought about it?
38,766 PostsLatest Activity: Jan 10, 2026
