mpierce
Aug 19, 2015Explorer
Turning the valve off works. However, it is a safety device. Most are hooked to a propane sensor, so that if you have a propane leak in the coach, it will automatically shut the propane off.
I feel the best option is to put a battery disconnect switch on the battery bank. I put mine on the neg cable. Make sure ALL neg connections are downstream from the switch. When you park the rig, turn the switch off. There will then be NO battery drain from the coach.
