dougrainer
Aug 19, 2015Nomad
RLS7201 wrote:
If you truly have a CCI propane detector, the solenoid is designed for low pressure and should be down stream from the regulator. If the system fails you can remove the solenoid valve from the system and replace the detector with an alert only detector. Or The detector can be repaired. There is a fellow (Larry) in Olathe Kansas that does CCI repair. You can contact him a [email protected] Larry does good work and offers good customer service.
Richard
His system the solenoid is on the HI pressure side. Once it goes thru the solenoid the LP then goes into the LP regulator. Doug
