dougrainer
Aug 06, 2017Nomad
MOST Asme tanks will spew LIQUID at the 80 percent valve when full. It would be interesting to see if that happens when the tank is full. IF NOT, then the Auto fill is defective and the float is probably bent inside the tank shutting the LP fill OFF too early. I would drain the tank completely and then refill after all vapor and liquid has been purged. Doug
38,782 PostsLatest Activity: Sep 10, 2026
