Sjm9911
Mar 17, 2021Explorer
No not advisable at all. People store them inside, some may use them, but i wouldn't. Whats up with the propane regulater? And how cold does it get? I dont think a regulater should freeze from the cold. In fact the house we used to have in lake george had an above ground propane tank, it worked fine. And it was cold there. Maybe you need a new regulater, or have another problem. Did the propane shut off or the heater? If you dont have enough make up air the unit will shut down. This is so you dont die from co or lack of oxygen. Likewise thats why its not a good idea to store or use propane inside. If it leaks or tips over and the head breaks , propane expands like 270 times displacing the oxygen in the area.
38,780 PostsLatest Activity: Jul 04, 2015
