time2roll
Mar 17, 2021Nomad
Frost on the outside of the cylinder or the regulator is not "freezing up". The cylinder will have a reduced temperature as the propane turns to vapor in the cylinder and again expands within the regulator.
I suspect you were just low on propane and the vaporization was slowing down. The warm water would have increased the rate of vaporization. May also have some Butane in the mix that does not vaporize very well at low temperatures.
38,780 PostsLatest Activity: Jul 04, 2015
