Lantley
Mar 18, 2021Nomad
BB_TX wrote:
Here is one explanation of cold and propane.
The freezing point of propane is -44 degrees Fahrenheit. The coldest temperature recorded in Newburgh is -20?F. So there’s not much reason to be concerned about your propane freezing.
But that’s not the end of the story.
While it’s unlikely your propane will freeze here, it can still be affected by very cold temperatures. Propane contracts when it’s cold. When it’s extremely cold outside, the volume of propane inside your aboveground propane tank will shrink, which creates a loss of pressure. The problem is, if the pressure becomes too low, the propane inside your tank will not be able to reach your gas burner. That means you may not be able to run your propane appliances, including your furnace or boiler, which can be very problematic in severe cold.
Good info. While freezing maybe the wrong term. Propane flow can be dramatically impacted by cold temps.
Describing the impact as freezing is easier for the novice to understand vs. stating propane "contracts" in the cold weather.
38,782 PostsLatest Activity: Aug 23, 2026
