kdk wrote:
I removed the regulator from the grill and installed a 10 ft hose with a male quick disconnect (similar to an air hose quick disconnect) purchased from a propane dealer. Then installed a shut off valve and a short hose from the fitting in the RV to extend to the outside of the baggage compartment with a female disconnect on the end of that. This allows me store the grill in a different compartment, shut off propane when not in use, and with the longer hose to grill away from under the awning. Lastly hooked the regulator that was removed from the grill to the adapter that screws into a portable propane tank with a female quick disconnect so I can still use the grill when away from the RV. Sounds like a lot of work but really not so, more time rounding up supplies than actually doing the job, but really works good. Also use the same hook up for the portable fire place. Send me a PM if you have any questions.
Blessings: kdk
Now this is a good idea. Going to a portable tank and still using the regulator. :) Grade A advice.
