BlessedFam10's avatar
BlessedFam10
Proper Generator Use
Hi all, just recently purchased a 2018 Georgetown GT5 series 36B. First time RV owner and would like any tips available on setting up my unit for the first time at a campground and if there is a checklist out there to go by... also I have a 7K Oanan generator and my question is do I have to run it while traveling or will my batteries power my AC effectively.
Thanks,
Ty
    Thanks,
    Ty
    Yep,
    It depends on which A/C you're talking about. As has been stated, the rooftop A/C needs 120VAC to run. The engine A/C needs, well, the engine. If the dash A/C is not keeping up with the heat in the cab, well then, you'll need to fire up the generator and, then turn on the roof A/C to augment what the dash is putting out.
    Scott
  • RV roof top A/C needs 110v
    shore power or generator power
    yes you can run the generator while driving,
  • If you are not plugged into shore power, and if you want to run the AC, you will need to run the generator. Your batteries are not able to run the AC. I run my genny frequently while traveling for that specific reason.
