usersmanual
Sep 15, 2016Explorer
JCMack wrote:
Two years ago I installed quick click vinyl floors tile in my rv. Living here in Canada the rv goes thru extreme temperature during the year. The top click portion on many tiles has broken off due to expansion and contraction. Luckily I have boxes of tiles left over so I will remove the broken tiles and glue them all in place including the tiles still on the floor which are still good. My question is which vinyl glue should I use none are rated for outdoor use. I tried construction glue PL Premium this works well but is very thick to apply. I would appreciate any advice on the products they have used to solve this problem
I have personally installed vinyl plank flooring in MH and never left any perimeter gaps. The glue you need is the glue that floor layers use to glue down Vinyl plank.its very thin and easy to spread.
must have a smooth clean surface.does not have be any such outdoor glue at all
