- nevadanickExplorerI was told that it had to be directly under the radiator to not disturb the airflow to radiator. I dont know the validity of that but it came from someone that had to move theirs after installing and having an overheat problem.
- Mile_HighExplorerI just took mine off and threw in the garage this morning. We are on the road next two weeks. Will see what happens. Mine was actually lowered 7 inches to fit the H-frame for the lift in the back. No wonder it drug around all the time.
Of course rain today, so can't tell if it did any good or not. - FiestaExplorerI'm getting better MPG due to less wind resistance, less toad damage and weight, without my last two. Anyone like a freeby?
- 2gypsies1Explorer IIIThey only serve as a flashy advertisement.
- crassterExplorer II
Nutinelse2do wrote:
We have read repeatedly that the correct placement is 6" off the ground, in order to avoid the above problems. Who knows though. Could be just an old wives tale from the road.
X2, I've heard this too, but have absolutely no idea if this is just tales or legit. - rgatijnet1Explorer IIII wouldn't worry about the full width mud flap. Damage only happens to others. :B
- Mile_HighExplorerI think the problem with mine is the folks that put the motorcycle lift on the back lowered the flap.
- Mile_HighExplorerSo theoretically they are there to break the windshields of tailgaters, but I was supposed to take it off if pulling my own car! :B
- pointrowExplorerI found out the same about taking it off here in Alaska. Before the first gravel roads with it the windshield got broke and bunch of rocks laying at the base of the windshield. Removed it and no more rocks. The whole toad stays cleaner without it.
good luck
pointrow - Nutinelse2doExplorerWe have read repeatedly that the correct placement is 6" off the ground, in order to avoid the above problems. Who knows though. Could be just an old wives tale from the road.
38,782 PostsLatest Activity: Sep 10, 2026
