Mr_Mark1
Mar 28, 2014Explorer
We have had our Aqua-Hot system for 7 yrs. and it has worked beautifully except for one time (not the fault of Aqua-Hot). I had a kitchen hose split that just happened to leak water on the Aqua-Hot circuit board which shorted it out. Once replace (hose and board) life was good again.
Our Aqua-Hot has two elements so we can have really hot water without turning on the diesel. If the outside temp is not too cold (45-50), we can heat the coach with the electric on with the Aqua-Hot.
Our new coach will have the Webasto system which is similar to Aqua-Hot but it does have a 20 gallon water heater. The water is heated when the engine is running (on both coaches).
Our Aqua-Hot has worked very well and we switched from servicing yearly to every two years as our fuel nozzle looked like brand spanking new at one year..... so, for the last several years, a two year service is perfect.
MM.
MM.
38,777 PostsLatest Activity: May 24, 2026
