lordnorth wrote:
Assuming that I went the way of 4 down instead of trailer... I am really thinking that the ReadyBrake perhaps with the added brake vacuum pump is the way to go instead of invisabrake.
The idea of invisabrake is nice, but if I read it correctly it is NOT proportional... in other words, the brake is either applied or not applied. So if you are in the habit of making long, slow stops (I teach tractor trailer driving so I am all about loooong slow stops) you will have disproportionate amount of braking from your Toad, on the other hand if you need a quick stop, you don't get any extra assistance from behind.
With the ReadyBrake a long slowdown will result in minimal braking from the Toad. The harder you slow down, the more braking you get from the Toad. Add in the vacuum pump (if necessary) and it seems to me that you have got almost the equivalent of proportional electric brakes.
Am I looking at this correctly?
Yes, I think you are. I also like the Readybrake, it is only braking system I'll own.
The other really, really nice advntages the Readybrake has over Invisibrake and other systems, you may or may not have thought about:
1. Cost - Readybrake costs SUBSTANTIALLY less $$ than any other system. If you get the Readybrute Elite tow bar and braking system combination, it saves you over $1000 for what you'd pay for a separate tow bar and most any other system.
2. Simlicity - No electronics to foul up and cause havoc with your brakes. Ever. Just simple, no-nonsense cable operated system that simply works. And, almost anything that might possibly break or wear out with it, you can get parts at any hardware store for less than $20 to fix it. The same cannot be said for most any other braking system. Also, the beauty of a mechanical system like this is that you can inspect may of its parts for wear & tear, fix potential problems before they become something breaks. Not the case for electronically controlled brake systems.
One of the things I really like about the design of the Readybrake is this: Once it is installed and set up correctly, it is just about impossible for it to EVER over-brake your toad and damage the brakes. The same cannot be said for many electronic systems.
As far as the brake vacuum pump: I've towed two vehicles with a Readybrake. The first one had no vacuum assist, and it did fine. The second one (what I tow now), is one of few vehicles where power (vacuum) braking stays on ALL the time, even when engine is off and/or when towing (Ford Fusion hybrid). Soo, brake pedal does not become 'dead' and tough to press when engine is off. With the Fusion, I have found that braking is a little bit better than it was on my previous vehicle that did not have power braking on all the time, but not significantly so.
If you go the 4 down route and get a Readybrake, I would try it first without the additional brake vacuum pump. You may well find you do not need it.
