rk911
Aug 18, 2014Explorer
et2 wrote:
As mentioned you need to know all your other MH's weights and where you stand. Including the GCWR & GAWR ... more weight in the rear hitch could put you over. " EVEN " if it's within the towable amount for the hitch.
correct. in general, the maximum amount of weight you can safely tow will be the lesser of the following:
* the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
* the weight rating of your tow bar
* the weight rating of your hitch
