willald
Aug 18, 2014Explorer II
You might find a trailer light enough to work, especially if you go with one that is open in the middle, something like THIS Carry-on model.
Biggest problem you're going to have with using a trailer is not so much the total weight of the trailer and vehicle exceeding your hitch's 5000 lb limit, but with the tongue weight. Your hitch receiver is most likely limited to 5000 lbs total weight, and 500 lbs tongue weight. Frequently by the time you load a 4000 lb car on a flatbed trailer, the tongue weight it will place on the MH hitch receiver is going to be significantly more than 500 lbs. If you get much over that, its not just a matter of beefing up the hitch receiver to one that can handle more tongue weight. You have to also worry about the strengh of any frame extensions the manufacturer may have added to the back of MH chassis, load/weight shift on the MH tires and axles, etc.
This is the main reason that every time I get tempted to go the trailer route instead of 4 down towing, I quickly scrap the idea. Only way I'd seriously consider trailer towing, would be if I had a MH that came with a 10k hitch receiver from the factory, so I know it was designed to handle the heavier tongue weight.
Anyway, for these reasons, I definitely agree with advice already mentioned, that you need to hit the weigh scales before buying anything. Sure would hate for you to find out after you're stuck with the trailer, that it won't really work, either.
