tatest
Jun 21, 2013Explorer II
The noise is usually not the pump, rather pressure pulses from the pump being transmitted to a sounding board somewhere in the water lines. Especially Winnebago installations, which isolates the pump itself, on a pad, and usually connects flex lines to the pump so that pump movement is not passed on. This leaves only pulsing in the water itself to transmit vibrations.
I think the more expensive pumps you are looking at work the same way, not inherently making for a quieter water system.
If the noise occurs when water is drawn anywhere, the culprit may be a line close to the pump laying loose against something. If only one faucet, then look at the lines to that faucet as possible culprits.
38,766 PostsLatest Activity: Jan 10, 2026
