DaHose
12 years agoExplorer
Yes, usagi. Many solvent based contact cements will dissolve the foam. Fastbond 10 is water based and once set it won't re-hydrate.
Remove your windows, remove the old sealant with acetone and re-set the windows with fresh butyl tape. Then use Alex around the outside. That should give you nice, leak free windows.
Finish everything by using some Eternabond around your top seams. That sucker will be well sealed.
If you just want it to last a bit and the structure is sound, then use some kind of elastomeric brush/roll on product to seal the rest of the roof for a few years.
Jose
Jose
38,781 PostsLatest Activity: 19 hours ago
