DrewE
Jun 18, 2018Explorer III
pnichols wrote:
For what it's worth ... I'd rather not need either blocks or jacks anywhere near as often.
How about a couple of features that are long overdue:
1. RV propane refrigerators mounted on gimbal'd frames so that they are always level.
AND
2. RV beds mounted on gimbal'd frames or with some kind of simple and easy to access four-corner bed jacks so that they could always be made pretty level.
I think #2 is called a hammock :B
If you're out of level far enough for the fridge to be affected (a couple of degrees), you'd also want the shower on a gimbal mount so it drains, and probably the stovetop so your eggs don't slide to a corner of the frypan, and...
For my motorhome, at least, the shower draining decently seems to be the most sensitive to inadequate leveling.
38,782 PostsLatest Activity: Sep 10, 2026
