gbopp
Oct 16, 2014Explorer
Can you fill a 5 gallon container at First Nations?
If you can, go to a regular diesel pump and mark the level after you put in 5 gallons, or however many liters.
Then use the marked container to see if you get less than 5 gallons at First Nations.
The difference may be small with 5 gallons but, it will add up when pumping 200 liters.
38,766 PostsLatest Activity: Jan 10, 2026
