Executive45
Nov 08, 2013Explorer III
Since you've used a meter, I can assume you have some knowledge of electricity. First check to ensure you have 12VDC TO the switch. Flip the switch and ensure you have 12VDC FROM the switch. If you do, then do the same to ensure you have a good GROUND as well. Does sound like a bad relay that hasn't reset, but do the simple stuff first. We always check for juice but forget the ground....good luck...Dennis
